1969 Evenrude 25HP shifting issues
coralman
My 1969 Evenrude 25HP will start and idle but I am having a hard time turning the handle low enough to shift into forward or reverse. I can turn the throttle just above the shift position and it will stall out. I have tried adjusting the low speed mixture knob so that the motor smooths out but I can only twist the handle just a tiny bit more towards shift and it will stall. There is a very fine line where I can successfully shift forward or reverse. I was out on a lake this past weekend and I would turn it down to where I thought I could shift but it would not go into gear or it would just barely engage and then drop out into neutral again.
Once I get it into gear, then it runs great. It is just an issue of getting the idle low enough to shift smoothly.
Any ideas of what to check, adjust or clean? Any help would be appreciated.
hardwater fisherman
Dont worry about those words written on the tiller. If you are stalling then you dont need to throttle back even more.What I do is set it to where it just stays running one way. And for starting just turn it the other way until it hits the stop. EDIT If you follow the tiller handle to the gear in back you should see a long plastic screw with a spring , that is where you set your idle.
