1969 Chrysler 85 HP Lower Unit Seal Kit??
Duoboater
Hello All, first post. I just purchased a 1969 Duo 3V7 with an 85hp Chrylser outboard model 8571. The engine seems to run well but I noticed the lower unit was leaking new gear oil I just put in the other day around the bolted area of the lower portion of the lower unit. I cant seem to find any lower unit seal kits going back far enough for my unit. Do you guys have any idea of where to find a kit or one that will work? I appreciate any help!!
Frank Acampora
Re: 1969 Chrysler 85 HP Lower Unit Seal Kit??
You can try franzmarine@aol.com. However, those seals are for the most part standard items. Remove the old ones without damaging the numbers and take them to a bearing supply store. They can match them but be sure to specify ALL Stainless. They cost a bit more, but you can't use seals with steel shells and garter springs.
BTW: Welcome to iboats forums.
