1969 Chrysler 55 hp
Boat Wife
Does anyone know where to buy these coil packs w/ wires. She ran Great the past 2 yrs now 2 wks ago out on the water all going Great then out of nowhere lost power finally got restarted then lost power again half way across the lake. Had to use the trolling motor to get back. Then the next day went to a lake close to home ran great headed back in to get the nieces & nephew 1 battery died so hooked up the other 1 got to dock & she wouldnt start anymore. We rebuilt the carb getting spark. Every no & then it will run a little rough for a bit then die & not start back up. Can anyone help us.
wickware
This was just discussed (about 2 weeks back) and solved on a 55 Chrysler close to yours. I feel “Nordin” recommended automotive coils. Try and PM a message to Nordin if needed.
Good Luck!
jerryjerry05
Sounds like it might have gotten hot?
Do a compression and spark test.
You sure the coils are the problem?If your getting spark????
Try new plugs?
wickware
Good Point Jerry! History on tuneups and maintenance helps in troubleshooting. Fire, Fuel and Compression basics should be known as working proper from routine maintenance and History.
Such as:
1. What type of ignition system do you have and when was it serviced last.
2. How do you service your fuel and how often?
3. How often do you check your plugs and run compression checks and get what readings?
Routine maintenance and observation is needed. Good Luck!
