huskerdaninva
Thread starter- Joined
- Jun 18, 2009
- 240
OK, after a minor issue with my newly rebuilt fuel pump (mud dobber mess in inlet elbow) I got my '69 70 hp fired up after a prolonged hibernation for major maintenance. (Cleaning/painting, new head gasket,water jacket gasket, rebuilt carbs and fuel pump, re-plumb all fuel lines, clean/set points, new custom wires, plugs, re-sealed LU, etc.)
I set the timing to 36 degrees at WOT and did the whole link/sync for the carbs, set air/fuel screws to 1 1/8 to about 1/1/4 out, etc. via my Glenn's manual and some guidance from here. She fires right up w/o choke at the bump of the key. Fires on all three cylinders, pumps water, doesn't get hot. I'm happy as a clam. My questions is about an occasional surge at idle. Now I realize that this engine isn't going to purr like your basic V8, but she'll idle up considerably (don't know the rpm's as my tach is not working.) some times and then slow back down. I was able to briefly put her in gear (Fwd) in my test tank at low rpm's and she idled OK and didn't die out. I thought perhaps the idle surge might be caused by low fuel level causing inconsistent fuel pressure as I had not put but about a gallon or so in the tank and she idled for a good 30 mins. She did eventually cut off from running out of fuel, so I added another 1.5 gallons mixed and she fired right back up but with the same occassional surge. I haven't had her in the water yet, but need to do a shake down cruise and want to try and cover my ample arse on everything prior to heading out.
Any thoughts? I can't really complain for a 42 year old motor, maybe that's just the way she idles??
