1969 6r69m 6hp shifter broken
draagyn11
Hi here - I have a johnson 6hp that has a broken shifter. It's broken at the top of the leg there.. already had the lower unit off and all looks good down there.
I've seen posts about this where people were forced to pull the whole powerhead off.. is there no way to get in there by just.removing the upper section of the leg ? Or do I have to disassemble the whole thing to fix the shifter ?
Thanks !
-Wade
Honorary Supreme Mariner
Powerhead must come off and then changing the shifter is easy.-------Not sure what you mean by " removing the upper section of the leg " here.-----------The powerhead is attached to the upper part of the leg by 7 screws !
draagyn11
Yeah okay.. right haha.. thanks.. so can I get away with just undoing those screws and pull the leg away or the powerhead off as one ? Or so I have to disassemble the whole thing pretty well ?
I have done 5 of these motors over the last winter.-------The powerhead is held on with 7 screws.--It will be easier than it looks to you at the moment.----Now that lever is fairly pricey and I have seen many backyard repairs to avoid spending the $$$ and save taking the head off.
