I have a 1969 6 hp fisherman, when i got it, it ran rough and struggled to push me and my 11' flat bottom boat through the water. after figuring out i had no spark in one of the cylinders i replace both coils and condensers and both plugs. after doing this it ran much smother but still did not push the boat very well through the water, would not even plane on the water. I did a compression test on it yesterday and got 60lbs on the bottom cylinder and 56 lbs on the top cylinder. my question is. is that compression good for this motor? what else could be the problem?
