1969 100 h.p. merc outboard ignition coil
bockyx2
Anybody know how to take the ignition coil wire off of the ignition coil side I thought it would just unscrew but it just keep spinning any info on this would be great thanks
Scaaty
Re: 1969 100 h.p. merc outboard ignition coil
If you have enough screw thread beyond the nut, grab it with visegrips at the very end, loosen the nut, then hack saw off the damaged threads..try to leave as much as possible
