1968 mercury 60 6 hp
gatorbear1956
i have one of these little jewels i just bought -thinking it had fuel problem- i flushed fuel system got it to fire and crank - went to change plugs [it would run an die] , discovered water seeping from small hole just below bottom spark plug [appears to be corrosion caused. looked online for hrs for the replacement part and a gasket just cannot seem to find either! think if i replace these i get some service out of engine!help!!!please!
M
Maxz695
Guest
Re: 1968 mercury 60 6 hp
CYLINDER HEAD Martin 6 hp 60 outboard motor parts
this is what i came up with nothing eles showing on eBay
M
Maxz695
Guest
is the hole in the head or the gasket? after searching it definitly say it,s and antique gonna be hard to find
M
Maxz695
Guest
JB B WELD RULES BUt make sure it,s dry totally befor sanding filing etc I did an AC line and it,es still holding a month later. and today I had my exhaust plate dry for my outdrive and the sucker is as good as new. TIP Sand the material before adding JB weld to insure adherance
M
Maxz695
Guest
Wow I like this site too i,m gonna have to sign up I may be a chevy man but when it comes to aqua marine i,m all MERC
