1968 Merc no spark
Sleepo
Just bought a 1968 merc 2 cyclinder that appears to be in good shape. Problem its having is no spark from the plug. Does anyone have any ideas as to what the problem is? Thanks
hkeiner
Re: 1968 Merc no spark
I deleted my comments. They did not apply to your motor's ignition system design :)
Laddies
Banned
Your 6HP has a standard magneto ign. system much like a lawn mower of the same vintage, one for each cyl. the only thing in common is the kill switch that shorts the points together to stop it. If disconnecting one of the wires to the switch don't help, you will need to remove the flywheel and check the points and condensers.
Sleepo
Thanks for the imput. Me and a buddy are going to sand the points and properly gap them. I guess after that we will check those condensors like you said. Thanks Again
