Re: 1968 Johnson V4 Golden Meteor - Cooling question
The hole is in the back side of the mtr abobut 8 " down from the bottom of the cowl right in the center of the mtr. Needs to be in a DEEP tub or the lake to pump.
I still can't find the hole . The only hole is on the rear of the engine , just below where the lid mates.. but it goes straight up into the engine compartment into the tab that the lid slides in to . You can see right through it. I have it in a trash can with the water level just above the flat fin thing ( the water line is right at the lower unit gear oil plug. I pulled the thermostat house and started it for a few seconds and nothing came out. I tossed the housing back on and tried again , water shot all over. I have yet to get it to move any water again. Maybe it was just water left in the head. I don't even have water coming from the exhaust anymore which makes me think it ws left over water from the last time it was ran..if that is possible .
Where did you buy your pump and how mch was it? I;m having a hard time tracking one down.
EDIT: Unless you are refering to the upper exhaust hole.. it's about the ID of a half dollar.. I have read that most of the exhaust comes out of the bottom, which seems to be true.. and the rest comes out from the half dollar size hole which is actually about 8" from the bottom of the lid. Geez, now I'm second guessing myself. I swear I saw exhaust coming from that hole...maybe it's not even the exhaust? I swore it was.
