78 is just a washer just replace it
79 is the orifice plug high speed jet I doubt it is missing look way inside the opening it is screwed in the back
use a flashlight and you will see a small hole in the brass screw in device itself.
if you see it don't mess with it without the proper tool .. just clean it and blow it dry
43 is a link post to tweak the upper low speed needle with a cam...... and it plugs the hs orifice channel with a washer
lots of carb have just a threaded nut to close of the hs orifice. a short stubby bolt
you don't need 43 to run the motor if you can seal of the HS opening with a plug.
you can always tweak the upper LS needle manually without the cam and link
if you are loosing gas (leaks) the carb could also be sucking air while underway and it dies.
that's it for me on this one good luck keep us posted on progress
