sabeadle
Thread starter- Joined
- Jun 12, 2020
- 7
Hello Everyone,
I have a 1968 Johnson 9.5hp, Model#: MQ-14E
Last year I had it on the water after years of sitting in the shed. It took a while to start but I eventually got it going. The issue I noticed right away is that there is no acceleration. I turn the throttle and there is no response beyond the minimal idle speed. We are back to summer here in Canada and I would like to get the motor running like normal. I haven't tested it on the water yet this year.
Some info:
Thank you,
Spencer
Some info:
- I tested the Compression on the two cylinders yesterday after I was graciously suggested to do so on another forum. Both are at 60PSI
- I bought two new spark plugs. Tested them yesterday as well by keeping it in the boot and resting it on the metal of the engine. I got a strong blue spark.
- Another point I am not sure is relevant. I did get the engine to go full throttle on the water twice last year after I ran a bit of seafoam in it. I am not sure if i used enough. But after I lowered the throttle it would not work past an idle speed.
Thank you,
Spencer
