1968 Johnson 6hp throttle linkages
kabfisher
I just picked up a 1968 johnson cd-25A 6 hp and while waiting for a water pump to come I noticed that there seems to be a linkage of some sort missing on the throttle to the carb. As it is now the tiller handle doesn't seem to move anything. I have not run it yet as it needed a water pump and I don't have a gas tank at the moment. I'm just wondering if there should be a cable or something that is attached to the tiller? 20150312_174311.jpg 20150312_174324.jpg
Xcusme
Welcome to iboats !!
It looks like a clean dis-assembly (the small metal stand-by clip..is where it should be). If you look underneith the flywheel, you should see a small bent piece of metal (about 2 or 3 inches long). This piece should fit into the hole (take off the metal piece) and replace the metal clip the way it is now. This will turn the armature plate in a normal fashion.
nwcove
hard to tell from the first pic, but there should be a piece of flat brass linkage from the tiller connection, around to the other side of the base plate. is it there?
kabfisher
Yep it was the arm underneath the flywheel. Thanks for the help!! :fish2:
