1968 Johnson 40 HP RDSL-30-C exhaust cov.
Taney37
Cleaning up a 1968 40 HP Johnson RDSL-30-C motor. The top of the exhaust cover has a fitting with tubing running to the automatic choke. There is a similar fitting on the exhaust cover below this tubing. It is threaded but nothing is attached to it. What is the purpose of this lower cover fitting?
Honorary Supreme Mariner
Very common question.----And a very good question too.-------Facts------That is the air inlet to a heat exchanger.----The heat exhanger is inside the exhaust manifold.----The air is pulled towards and into the carburetor via that long tube.------The hot air goes over a bi-metallic spring to control tension on the automatic choke flapper.----That is it and simple I think.
Taney37
Thanks for the info. Always makes me nervous to see an open fitting and not know why it's there!
