1968 Johnson 40 HP idles but bogs out at 1/2 to 3/4 throttle?
Hello, I have a 1968 Johnson 40 HP - Model # RKL-30A Electramatic Shift. This motor has been sitting since 2003. However, I have pulled apart and cleaned everything for the most part (carburetor, lower end, Ect.). The issue I am having is this: when you pull the start lever the engine fires right up and idles great, I can rev the motor up and down with the start lever no problem. However, when I move the shift lever the engine runs great until I get to 1/2 to 3/4 throttle then it bogs down and stalls. I am running 89 octane 50:1 ratio....... anyone else have this issue?..... I am guessing a couple of thing just want your opinion ( float in bowl needs adjusted, fuel line needs replaced, air in the fuel line?) any opinion would be appreciated.
Thanks
Andy
Did you remove the high speed jet for cleaning ? ----It is found in the bottom of the float bowl.----------Do you have actual spark that will jump a gap of 1/4" or more on both leads ?-------Have you done a compression test ??
Watermann
Another thing to check on is the fuel pump, sometimes the diaphragm gets stiff with age and they won't supply enough fuel for higher speeds.
thanks all found the problem. in the bottom of the carburetor float bowl is a gasket made of cork it had broken in two. replaced for 4.00 and now runs good as new thanks for all the help!
Andy
