I bought this 20hp engine and was told it had been sitting up and needed carb. cleaned to run , so I took the carb. apart real carfully and cleaned it out.. I noticed that the carb. had a brass shaft that screws into the bottom of the carb.its the shaft that the rich and lean knob goes on and it was JB welded in the carb. so I left it that way and put cab. back together and it will start and idle kinda rough but when you turn the throttle alittle above idle the thing dies like you cut all the fuel off? can someone please tell me of something else to try... got new plugs and has hot spark... Help Please
