1968 Johnson 20 HP Lower Unit Reinstall
Rambo23
I sent my lower unit to the shop to get it re-sealed. I have a couple of questions about re-installing it once i get it back.
1) What needs to replaced when installing it. I see an o-ring on the tip of the drive shaft. Gasket on the cover plate for shift rod attachment. Other than that i dont see much.
2) When i removed it there was no sealer or gasket between the lower unit and exhaust housing where the lower unit bolts on. I was thinking that these metal to metal surfaces would need it but i guess not. I just want to confirm this.
3) Any tips, tricks, or advise for re-installing it.
Rambo23
4) Shop manual says to use Perfect Seal #4 on the screws that attach the gearcase to the exhaust housing. Whats a modern version of this?
F_R
Honorary Supreme Mariner
1. That o-ring is vitally important. Make sure it is in good condition, and smear some grease on it and the sides of the splined shaft, and on the water tube where it enters the pump grommet
2. Nothing needed. It doesn't matter one bit if it leaks.
3. Use a flashlight to peer in there and make sure the notch in the shift rod is perfectly aligned with the screw hole in the brass connector before inserting the screw. If not aligned, it will destroy the threads on the screw and it will fall out.
4. OMC/BRP Gasket sealing compound. Or Permatex, the kind that comes with a brush in the can.
James R
Dont forget to grease the splines on the drive shaft and prop shaft.
Rambo23
Thanks for the help guys. One more question. How much should I torque the bolts that hold the lower unit on to?
