1968 Johnson 20 hp fd 22m crankshaft key sheared
steinbro
I have a 1968 Johnson 20 hp fd 22m Just did a lot just over last week and had it running than. I went 8 days later to start it up make sure all is well and it wouldn't start so I was looking at the magneto section and have noticed the crankshaft key is sheared. I was wondering how to get it out? and also would than be sheared due to the coils(New) are to close to the flywheel?
jbuote
Not a pro here, but the flywheel key probably sheared because the flywheel nut wasn't torqued properly and was too loose..
If you have a piece stuck in the crankshaft, you could try to use a pick of sorts to gently pry it out, but be careful not to mess up the crank...
After it's out, use new OEM key and torque down with torque wrench. Run it, then double check torque...
May not need re-torquing, but I do it anyway when I have my flywheel off just as a double check after running a bit...
If coils aren't rubbing on flywheel, I think it'd be ok.. Don't have coils under flywheel on mine though (different engine), so I'll leave that for others to comment on...
Again, not a pro, but that's my thoughts on it in case it's helpful... :)
F_R
Honorary Supreme Mariner
Flywheel and crankshaft tapers MUST be clean and dry.
Flywheel nut MUST be tightened to 40-45 foot pounds, using a torque wrench.
Failure to comply will result in a sheared key, and damaged crankshaft, or damaged flywheel, or both.
Read and believe.
LK_Shastina
You'll have to strap the flywheel to prevent it from turning, or use a pry bar exactly as designated by factory to jam flywheel while torquing flywheel nut.
Make sure there is a flex (dome shaped) washer between the flywheel and nut, dome side up.
There just might be aluminum from the flywheel galled onto the tapered steel shaft. If so, carefully remove it with 600 grit oil emery cloth lubricated with oil. The same goes for the flywheel shaft hole, and if so, be gentle and careful not to deform hole.
steinbro
Thank you all for the help. After all suggestions comllete the motor starts up and runs great. Thank you so much.
