1968 Hydroswift
Shaffer89
I recently purchased a 1968 14.4ft Hydroswift fiberglass boat. While I was inspecting the outside hull for any notable damage I found a couple patches in the fiberglass that look like a very quality job had been done. But as I get to the transom I found something that puzzles me. At the bottom of the transom near the drain plug there is a patch job that looks terrible and I'm the middle of that there is a smaller hole that looks like some kind of drain plug. My father-in-law says it looks like somebody drilled a hole to mount a transducer or something of the sort and decided they didn't want it there and did that patch job. Neither of us have seen this on a boat before. As I was washing the boat I noticed that I had gotten some water in the bow in front of the foot plate and it puddled there. I hadn't even gotten the transom wet yet but I noticed that water was slowly dripping from that little hole and from the patch. Is that little hole some kind of bilge or drain incase water gets under the floor? Anyone know what this hole is or if it's even supposed to be there?
sphelps
Almost looks like a pick up tube for a speedometer that has broken off ... To small to be under deck drain with no plug ... I would be inspecting the transom for rot ...
Shaffer89
No Title
There is a speedometer pick up off to the right. Not sure if that's the original set up or not. That small hole is basically right behind the motor. In the picture the speedometer is to the right of the motor, kind of hard to see. The floor and transom are solid as a rock, although I haven't cut into any fiberglass to check the condition of the wood inside. I'm afraid to because I don't want to mess up the integrity of the boat.
