1968 Evinrude Lark X 40hp - shifting is reversed!
deed 22
Hi people.
New here... great community, looking forward to some help.
I have a 1968 Evinrude Lark X 40, Model 40872C. It has spent more than its fair share of time in the shop, and by rights I should walk away from it. But I like the old motor, and don't want to give up on it. My talented local outboard mechanic Steve did some work on it last fall, as it was not shifting into reverse. He replaced the entire lower end for various reasons (including that he had the parts salvaged from other motors so not a huge expense).
Using it for the first time this year, I find it reverses when put in forward and goes forward in reverse (and only at low revs).
I figured probably a simple wiring issue, and I'd bring it back to fix.
Unfortunately I then found out that Steve has deceased (RIP). So before I haul the boat much further away for repair I thought I'd look around here. I saw in another thread (regarding a different motor) that switching a Johnson lower unit into a Evinrude could cause this. Just throwing that out there.
Any other suggestions, and if that is the issue, how can I mitigate?
I would like to offer suggestions to whoever I get to work on this, as mechanics knowledgeable about these old motors are getting harder to find.
Many thanks!
Honorary Supreme Mariner
Find the electric shift wires on the motor.----Slide the rubber boots back .------Switch the wires.------Switching from Johnson to Evinrude parts makes no difference !!
deed 22
Many thanks, racerone. I will try that and report back (won't be on the lake for 2 more weeks, so stand by.
by the way, here is a picture of the old girl. She actually runs great, the problems I have had with it are typical age-related things. However compression is 100% and she just sounds like a motor should.
Boat is on lovely Consecon Lake, in Prince Edward County, Ontario.
These are very good and simple motors.----I have boxes full of parts for them in southern ONTARIO.-------Make sure the generator is working and keep water out of the lower unit.
