Good Morning,
This motor has been nothing but a pain in the behind for me. I bought the motor and boat cheap so i knew the problems i was getting into. I have rebuilt the carb along with changing the bowl gasket and intake gasket that comes with the kit. I have also went ahead and changed the head gasket since i had a really rough idle/ running under load issue. Here is the kicker, once i replaced the head gasket it ran perfect for 3 trips than back to running rough. Monday i replaced both coils and plugs after diagnosing a weak to no spark in the bottom cylinder. I also went ahead and reset and cleaned the points just to say i did it. I took it out yesterday and the motor runs good for about 15 minutes under load than goes back to what seems to be a misfire. I can get it up to full speed but it takes time until it finally grabs, once at full speed it will run with no misfire or hicups. This forum has helped me alot with issues on this motor but i am not at a stand still and do not know where to go next. All bolts and the flywheel nut have all been torqued to the recommended torque settings. Any and all help is appreciated.
Ryan
Ryan
