RickFortin
Thread starter- Joined
- Aug 20, 2012
- 11
I have a 1968 Evinrude 40hp select shift lark. It was working fine, then 3 weeks ago at full throttle it started popping out of forward. I changed the lower case oil with the proper electric shift oil, and did notice water in with the old fluid. I returned it to the water and it worked, but, it was still popping out. After a couple hours, both forward and reverse stopped working all together. I changed the lube, which had water in it. after a couple hours in the water, when I put it in forward or reverse the motor would stall. I repeated new oil, and now all I get is reverse. When I put it in forward, it goes into reverse.
I am going to pull it apart to find out which seal is leaking, and fix it, But, before I do that, I was wondering if there is any way to tell if the lower electronic cylinoid is junk now? Also, the motor runs really nice, is this motor worth putting money into? Or should I just look for another motor?
Thanks.
Thanks.
