1968 Evinrude 18
SethHoward78
Hello, new to the forums and was told about this from a youtube video. I just got a 14' Alumacraft with an Evinrude 18. The Evinrude is a 1968 Fastwin and I'm trying to get it started. Being new to outboards, do I need a batter for it? There are two cable running out that look like an electric start but I'm unable to find pictures or videos of it online.
Thanks for any help.
Seth
flyingscott
If they are red and black yes you can use a battery. I had one and I don't believe it charged the battery so it would be optional to have a battery. You could just use the pull start.
SethHoward78
Thank you flyingscott. I tried the pull start but couldn't get it to start that way so I assumed I needed the battery. Will have another look at it tomorrow then.
Thanks again!
oldboat1
might be shorting wires if coming down from under the flywheel. Think they were standard. Thinking you had to get into the 33s for an electric start option, and the electric shift 40s for a generator. No alternators yet, I believe. Good solid motor (the Fastwin) and will give you a quick rig with the Alumacraft.
F_R
Honorary Supreme Mariner
Electric start kits were offered as an accessory on that motor. Battery cables are pretty thick. Kill wires would be skinny, if that is what they are. Just a quick glance with the hood off will tell if a starter is present.
oldboat1
Add that "kits" can be a PO's creation too, which can be fine if they work. If you don't have an electric starter but would like to add one, do a search or two with the search engine here (top of page). Also can open a thread and get lot's of input.
SethHoward78
Here is a view with the hood off. I went back out and was not able to get it to turnover. Spark plugs are new, fuel line looks good.
SethHoward78
E18leftside.jpg E18rightside.jpg E18serial.jpg Alright, took the hood off and this is what I have. It wasn't catching with the pull start. Checked the spark plugs and they are new and the fuel line seems fine.
F_R
Yep, that looks like the accessory electric starting kit.
oldboat1
Starter is kind of a hint something is going on.
Show the wires you described "coming out". If they are the size of those shown inside (the larger ones), they are presumably for the battery hookup. Black goes to negative, red to positive -- red would be the one coming out the right front from the square switch (your solenoid). Black would ground to the block or pan somewhere. It looks to me like a PO has used a kill switch (lower cowl) for a starter switch -- which could work.
You can pull it off if you don't want it, but it might work fine.
flyingscott
If the pull start is not catching the flywheel take it off and clean around the pawls could be old grease making them stick. Don't take the electric starter bracket off they are rare and pricey.
tomhath
Master Chief Petty Officer
Have you checked that it has a spark? Not just a tiny spark across the plug electrodes, but a big hot spark you test with a spark tester. Most likely you need to pull the flywheel and have a look at the coils and points.
Roberthill
If you just want to see if It will start get a set of jumper cables hook the negative to the motor and hot wire to the starter .
SethHoward78
Hey guys, wanted to follow up with you. After doing some more dining around, found that my choke was sticking. Was able to fire it up today and keep it running.
oldboat1
well done! Impeller replacement? Don't want to have an old one disintegrate on you.
