Russ060
Thread starter- Joined
- May 22, 2020
- 12
Hello Everyone,,
I hope you are doing well during this pandemic
I'm getting into outboards and got my hands on an 1968 Chrysler 20 HP motor. the only problem it has is that the wiring is kind of hard to figure out (at least for a starter noob like myself, where I almost fried the starter plate, if it's not already fried :\.
I'm going to post what I did with pictures and I hope one of the old motors enthusiasts, will be able to help me get this motor started as it's my summer project.
I tried to follow the diagram below, however, that was a total failure and the stator plate started smoking, although I disconnected the battery right a way when I smelled the smok.
The key switch for the engine is a universal key switch as shown in one of the pictures, however, after following the diagram, the alternator seems to run on the battery instead of making electricity and sparking the plugs. in other words, when the switch is on the ON position, not ignition yet, the alternator will run and since the engine isn't firing some smoke will come out of the stator plate (coil and condenser)
I believe my mechanical voltage regulator is broken from the bottom side, (burnt), but still there's continuity, and from my understanding, it shouldn't prevent the engine from igniting as all it does is charge the battery after converting to DC.
I'd really appreciate any help or advice to point me the right direction
thanks for taking the time to read my post
regards
regards
