Re: 1968 9.5HP Where is this water comingfrom? W/PIC
NUTS and Phooey!!!
#1, that water is coming from two big drain holes in the exhaust housing. It originates from the water pump, coming out through the hole that the drive shaft goes through. It is absolutely normal!!! However, if the pump housing is badly worn, it will leak more. If those drain holes weren't there, the water would go up the drive shaft tube and damage the powerhead.
#2. If you can grab the flywheel and move the powerhead fore and aft more than just a rubbery feel, the upper front motor mount is broken. That was a very common problem with the 9.5 motors. It is a major job to replace it for a pro, and very intimidating for a novice. I've replaced so many of them that I almost could do it blindfolded. I was a dealer mechanic, servicing a fish camp full of them.
