1968 9.5 9822e Thrust, propulsion issues
Woodya08
I have 1968 Evinrude 9.5 sportwin. Runs great I had no issues until today. I was on the river going slow running fine. I ran into a sand bar and accidentally throttled it while in forward. I put it in neutral cut the motor, worked my way to deeper water. The motor started immediately went in to gear fine however, when I gave it gas I was only going half speed. Reverse and forward work fine. The motor seem to run good, but even when I'm at full throttle I'm just barely putting around. Any ideas? I cleaned points and new plugs last month, used it last week for 4 hrs no problems. Thanks in advance.
F_R
Honorary Supreme Mariner
So, when you give it the throttle, what happens to RPM? Just half? Or does it race high RPM but boat doesn't go? In the first scenario, either the throttle isn't opening up, or it is running on one cylinder. In second scenario, you spun the prop hub.
