Re: 1968 6hp Johnson
Not on a 1968, if you are sure that's what you have.
Remove the spark plugs, put motor in forward gear.
Remove the four bolts holding the lower unit on, and slowly turn the flywheel while dropping the lower unit down. There is a pin in the shaft which has to come down through a slot. As you turn the flywheel, the pin will "find" the slot and come down through it.
When you are able to get it down about an inch, look in the gap and you will see the brass shift rod connector. Remove one screw from it and then the lower unit will com on down and away.
Note the position of the pin so you can put it in the same position for re-installation
