1968 55HP Johnson Stuck In FWD
Timbo1
Ok so I resealed lower end on johnson 55 hp 1968 now it's stays in forward and gear lube is full and it has power to lower end for electronic shifting days I been messing with it now can't figure it out any help would be appreciated
GA_Boater
Welcome aboard, Timbo1,
Moved into the Johnson/Evinrude forum from the Merc forum.
Honorary Supreme Mariner
Is the motor running / turning when you are checking the shifting ??
jimmbo
When you say it stays in Forward gear, do you mean when it is running, or when it is not running? That gearcase defaults to forward gear when not running, or running if no power is going to the shift solenoids.
