1968 55 evinrude triumph spark problem
runabout68
Hi
I have a 68 Evinrude Triumph 55 hp and I am having the following issue. The motor will not spark until the key is back to the on position ie. not cranking. which gives me a back fire. I have jumped the key switch but that is not working. I have a brand new battery and I also replaced the amplifier. There is a ticking noise coming from the amplifier when the key is on. I reset the points to exactly .010 new coil, new plugs. Any ideas?
Thanks
Bill
Test and inspect the starter motor.------Perhaps it is drawing too much power away from the ignition system.------And how big is the new battery ?
F_R
Check the voltage at the amplifier input while cranking.
Wiring ( corroded ) is known to be a problem on these motors.-----------Wires may look ok but can not carry proper current.
Tim Frank
^^^^ +1
You may have to rewire the motor electrics. It is not difficult.
I had the Johnson version and redid the wiring after trying all sorts of ignition troubleshooting.
That solved all the issues.
There are several threads in here on replacing that wiring.
runabout68
Thanks for the responses. I'll have to check the wiring. It's kind d of frustrating because this motor had good spark but ran on two cylinders because of dirty carbs. I took all the carbs off and rebuilt them and found 1 of the jets clogged. After I got them reinstalled, no spark.
