1968 35HP merc spark problem
grizz11
I was given a 1968 35HP merc Magneto system. I have installed new points, condensers, when using a ohmmeter on the terminal block it shows continuity when I open the points no change. However if I discount the ground wire on the laminated core and run the test have continuity with the points closed and then with the points open it test correctly.
I have no idea what my problem is?
17.5cobra
Re: 1968 35HP merc spark problem
Have you checcked the ground itself ... Is it well grounded????
I had a similiar problem and the bad ground was my problem.
grizz11
I think the ground is good. When I put a spark plug light tester on and ground it to the motor the spark comes through however I think is coming from the ground to the tester.
Laddies
Banned
Your OHM meter is reading the ground through the primary winding in the coil. that's normal. It should read .50 to .65 resistance
