Kurt James
- Mar 5, 2017
- 9
I have a 1968 Johnson 20hp outboard (Model: FD-22M) with an odd fuel leak seen on the water surface. I can smell that it is unburnt fuel and it "rainbows" on the water surface. I thought it was potentially piston blow-by but I tested cylinder compression and both cylinders have great compression at around 110psi each. There are no leaks or smell of unburnt fuel under the engine cover. No fuel line leaks though out fuel system from tank to carburetor, no carburetor leaks & no leak from the oil tube (runs from lower piston to upper piston). It is only seen with engine running. There are no leaks with engine off when squeezing primer ball either. The engine also runs great with no performance issues. Lean to Rich fuel adjustment also makes no difference. Has anyone had this issue? Any suggestions for next steps in root cause?
Thanks, Kurt
Thanks, Kurt
