sparkplug619
Thread starter- Joined
- Sep 14, 2016
- 24
Hello again. I just got my 1968 FD-22M tuned up and on the water.. it runs pretty good minus a few hiccups.
One of the main hiccups being when I fire it up (starts on first pull every time) it idles nicely as long as I have the throttle on a certain bracket when firing. When I pop it into gear, it is able to push away from that bracket and the idle drops far enough to shut off unless I have a hand on the throttle, keeping it in range of that little bracket thing
The first picture shows the motor at idle. If I twist to full throttle and pop it into neutral before starting it will lock onto that plate shwon in the picture, not allowing the idle to drop and kill the motor
This picture shows when I throw it into first gear with my hand off the throttle. As soon as it goes into gear, the throttle will move down and start to close, causing the motor to bog down and die, unless I keep my hand on the throttle,allowing it to stay close to that tab and stay alive.
I have an understanding of this motor, Ive rebuilt the ignition, fuel pump, water pump and carb...I just have no idea where to even begin troubleshooting this problem.
