1968 20 HP FD-22a outboard questions.
B_N_G_13
Hey guys and gals, Recently acquired my first boat and have some pretty basic questions regarding my outboard.
Question 1: I have figured out how to properly trim the motor using the trim pins but when i run my boat motor for any length of time and put my hand on the exhaust housing (#4) right above where it steps up and exhaust water is ejected it is very hot, almost to hot to touch. Is this normal or do i have a water pump problem?
Question 2: Is the circled area in red on the attached picture normal it looks to the untrained eye (my eye) that this may have been broken off.
General Info: When trying to start the boat i pull the clutch give it a little gas turn the key and it starts right up. I can start this motor in gear which i assume is normal correct me if im wrong. I am running a 50:1 mix that was in the gas tank when i got the boat so i dont know what oil is being used. Any comments and help would be appreciated
Thanks, Guys
hardwater fisherman
I do not think it is normal for the motor to start in gear. Also be more worried about the temp of the power head and not the midsection.
F_R
Honorary Supreme Mariner
1. Your pictures do not show.
2. If the powerhead stays cool, you should be ok. But if you don't know when the water pump was last changed, you should do so. Don't wait for it to fail and burn the motor up.
3. Your motor did not leave the factory with an electric starter. It has been added, either with the factory accessory kit or piecemeal. The factory kit will start in gear. If it is a piecemeal deal, anything is possible.
oldboat1
Welcome aboard -- think you might need a few posts before uploading pictures. Might be time to change out the thermostat along with the impeller, particularly if you run in saltwater or rivers. Can't effectively run that one on muffs, so test or flush in a barrel with water about half way up the shaft, idle or fast idle only. 50:1 is good. Look for TCW-3 rating -- brand of your choice. When the tank gets down, good to clean it out before fresh fuel, just in case.
B_N_G_13
Update #1
So today I filled a trashcan with water and ran my outboard in idle for about 3-5 minutes on two separate occasions. My powerhead stayed at about 120 F max measured with a laser heat gun. My exhaust water never got to hot. The powerhead was never to hot to hold my hand on so i assume it is getting cooled properly. There was a pretty significant mix of oil in the water after i was done running it but that is probably to be expected from an old motor. My next step is to take it out and run it while monitoring powerhead temp. I will likely order a water pump and new O-Ring as a replacement regardless never hurts right?! Any other helpful tips from you guys?
oldboat1
Sounds like you're on track. Temp is good. Exhaust nasties in the barrel is normal -- might try adjusting the idle needle on the carb, maybe slightly leaner (clockwise).
Install a new impeller now !---Most folks wait till it is too late.---There is no warning or shut down system on that motor ?
