1967 Sears 3.5 hp fuel connector
re613
Hello all, I am trying to locate a fuel line connector for a Sears and Roebuck 1967 outboard (made by Clinton)air colled motor. This has a large ugly looking connector. The Sears model # is 582 6091 serial # 74622, If there is a way to modify this I will try and do it. I purchased this off of Ebay and the pictures may still be there Item # 4612290072, Thanks for any help you all can give me.
JB
Re: 1967 Sears 3.5 hp fuel connector
Howdy, Rauanheimo.<br /><br />Welcome to iboats. :) <br /><br />Back when I collected a lot of uncommon small outboards (with fuel pumps) I always converted them to use OMC fuel line connectors. That way I only needed one tank type for several engines.
WillyBWright
Welcome to iboats :) <br /><br />Google Sears Parts Store and have your model number ready. There isn't much hope, but you never know until you try.
re613
Hello, I checked sears and no luck.<br />JB, Just how can this be converted? Where he fuel line connects it is cast aluminum then takes a right angle up thru the fuel valve then into the pump (I think). This piece is one part about 4" long.
steelespike
My old Clinton built motors original connector<br />was a Chrysler connector may be available right here on iboats 18-8071 male fitting,18-8062 fuel line connector.
