1967 Johnson Super Sea Horse 33 Hp.
Big al1964
I just replaced the rubber seals O-Rings bearings & seals & I'm still getting water in the Gear case.? any Idea's would be greatly helpful.!
Tim Frank
List the parts that you replaced, clearly.
Pressure test the G/C under water. Tat will show any leaks.
Honorary Supreme Mariner
The shift rod o-ring is often overlooked.-But it is a major leak point if it is 50 years old.
