1967 Johnson Electromatic Shifting problem
lucabrazi
Marine rookie, just bought my first boat. The motor is a 40hp 1967 Johnson Electromatic super-seahorse. Took it out today:
When I shift into forward, the motor engages and runs in reverse. When I shift into reverse, the engine RPMs increase but doesn't engage (Still in neutral?)
Thoughts?
Thanks in advance.
F_R
Re: 1967 Johnson Electromatic Shifting problem
Obviously the wires are messed up.
At the rear of the powerhead, you will find a cable with two wires, coming up from the lower unit. There are rubber sleeves over connectors on the wires. Slide the sleeves back and disconnect the wires. Now, use a voltmeter to check the voltages on the (engine side) wires. Should have 12V on the green one when in forward, and 12V on the blue one while in reverse. No voltage on either when in neutral.
OK, if it passed that test, reconnect the wires and repeat the test. If you get funky readings, the cable going down to the lower unit is burned up. They don't make them anymore.
Under no circumstances should you run the motor with those connectors exposed and any possibility of them touching each other. It they touch while running, something expensive is going to bust.
