Daddypleo
- Jun 26, 2011
- 70
I had a problem with my motor not starting so I opened the hood to look for a neutral safety switch. Then I noticed that the shifter wouldn't go into reverse. At the top of the shift lever there is a spring and a disc under the flywheel that moves. I moved it back about a half inch and the motor started right up and ran very well. So I experimented with it and moved it back a half inch and it wouldn't start again. I moved it back once again and it started and ran great. Is there a screw that is supposed to be in there to hold this disc in place or do I have other problems? In other words, is this disc (I'm assuming its a throttle advance device or an armature plate ) supposed to move at all? If so how do I keep it from killing the engine?
