1967 Evinrude Fastwin 18 hp shift linkage issue
CarltonOfFairhope
I replaced the impeller and now that I put everything back together, I can only shift into reverse and neutral. I can't get it to forward. I have removed the lower unit and manually placed the drive shaft down in the lower unit and the shifter in reverse. I have also placed the shifter in Forward and manually positioned the lower gear rod at the high point, but no matter what I do I can only get reverse and neutral when I run the engine. Can anyone give me a DIY solution? Thank you
F_R
Honorary Supreme Mariner
Shift rod all the way down is reverse, all the way up is forward. If you have it put together correctly it has to work, if it was working before. Are you sure you have the screw in the brass connector aligned with the notch in the shift rod?
CarltonOfFairhope
Thanks F_R. Friday afternoon I took it by a local boat repair guy and he discovered that the top bolt guide had slipped up a bit on the upper shift rod. Therefore the upper and lower shift rods weren't meeting properly. After the adjustment we (he) got it aligned properly.
Thanks for your reply. Have a good day
