macgyver 08
Thread starter- Joined
- Aug 12, 2010
- 6
ok so i got a 1967 evinrude 6hp fishermen for $50 rebuilt the carb noticed on the intake that that one of the studs for the carberator was stripped (by previous owner then tried to epoxy the stud in) so i replaced the manifold and gasket. the motor runs and idles fine and throttles up in nuetral but when put in gear its like it has no power tested it on a 1436 jon and only got 5mph been thinkin it through and checking everything even checked the compression wich was less then 30psi on both cylinders which tells me that the rings are gone? any way to get a engine rebuild kit for this motor i have tried looking with no luck any sugestions would be great
thanks
Jon
thanks
Jon
