FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Hi there, I got my seal kit for my 67 Rude Sportfour 60hp. I see that I will need to remove the needle cage bearing on the output of the prop shaft. Is there a good way to do this? The rest seems fairly simple...I hope.
Thanks Zeph
I'm thinking that gear case is not a split case so you take the screws out of the gear case head assembly and everything slides out the back. Is the bearing stuck in there?
