1967 Evinrude 3hp Yachtwin Model 3736c
RJ045
Need to install new impeller which I have was wondering if there is anything special I should know or just the 4 bolts on the bottom to drop the bottom end also what gear oil 80/90 ?
Thanks in advance
Joe Reeves
Nothing special, rocket science mentality not required..... 4 bolts, drop it, that's it.
Be sure to use sealer between the impeller plate and the lower unit and also between the housing and the plate.
Make sure the water tube is installed properly. Lining up the D/S splines can be a PITA at times.
Gearlube is "HiVis" 90w.
