1967 Evinrude 33hp Ski-Twin
Boat461
Working on my first outboard m..otor and have some questions. I removed the carb to clean as the engine has sat for 3+ yrs. What are the recommended low and high speed needle settings? the low speed was set at 3 turns from the bottom. I am looking at buying a "Evinrude Outboard Motor Carburetor Kit 396701" kit to re install on the carb. Is this the correct kit? Has anyone installed a impeller/water pump on these motors? I haven't checked if it is any good. I ran the motor once but had rabbit ears on it which force water thru the cooling system.not sure if I have a bucket to run the engine in to see if it pumps water.
There is no " warning / shutdown " system on the engine !-------As a new owner step # 1 is a new impeller.
There are numerous sites where you can find that information .---Including this one here.
lindy46
Carb kit is OMC 439074 or Sierra 18-7010 (without float) Impeller is OMC 0775521.
tomhath
Master Chief Petty Officer
The manual I have for a 1969 model says idle 1 1/4 turns and main 1/4 to 3/8 open, adjust as needed from there. Idle should be around 650 RPM in forward gear. Spark plug is J4J.
jimmbo
My manual says the High speed needle setting is 3/8 to 3/4 open. I would start at 7/8 open and lean it from there.
oldboat1
Tune it in a barrel or in the lake, with water level about half way up the leg. Initial settings are meant to get the motor up and running so you can dial it in. Make adjustments with the motor warmed up and idling in gear -- idle setting first, then high speed when underway (then back to idle needle for final tweaking).
jimmbo
My Evinrude owners manual says to adjust the Low Speed needle "After" the High Speed Needle has been adjusted
Correct.---------Set high speed first then the low speed.---------But some will argue that I suppose.
oldboat1
no argument on the procedure -- just that initial tuning in a barrel places some limits. Can get it close, then refine on the lake.
