1967 evinrude 18hp
soxfan1965
Im having a hard time shifting from neutral to forward or reverse. Also lots of fuel spitting out exhast.
geoffwga1
You don't say whether remote or tiller,if remote check the linkages and in either case check your lower unit oil.
F_R
Is it running on both cylinders? If not, the throttle may have to be advanced to keep it running on the remaining one cylinder. An interlock prevents shifting at high throttle settings. And the non-firing cylinder will be discharging the fuel, unburned.
EDIT: A ruptured fuel pump diaphragm will cause the conditions I just mentioned.
