1967 Evenrude 9.5HP
SRB14
I recently restored the gear case on my 1967 Evenrude 9.5 hp motor. Before reinstalling it I insured that it shifted properly by moving the shifting rod. After installing I found that it would shift from neutral to forward but not into reverse. Any ideas on what the problem is?
sutor623
Is the motor running when it wont shift into reverse? If the prop is not spinning then the motor will not shift into reverse. Fire her up and see if she goes into reverse.
lindy46
Possibly the shift rod is not in the proper spot in the coupler. There is a depression in the top of the lower shift rod which has to line up with the coupler bolt. If you pushed it too far up (past the depression) that would explain why it's not going into reverse.
