Hi All. Its been a real pleasure trawling this forum and I have gleaned many pearls of wisdom from this fantastic forum of late. Really super stuff.
I recently acquired a 67 chrysler 45hp to power my 16ft Volero 16 footer. (not a Larson Volero, its made by the Australian Volero Boat Co and is a halfcabin). I've seen the motor run, change gears etc but now that its time to connect to my tub, the wiring has me rattled. I have attached a pic to help explain my problem. The starte solenoid post that connects to the starter motor also has a red wire going to the silver unit? I also need to wire a new key start. Loking at the block connector panel, I really dont know what does what. I only know that the 2 black lamp wires are the magneto cut offs and I suspect that the rest of the solenoid arragement is wired incorrectly. I have a wiring loom with over-heat alarm but not sure if the motor has a sender unit for it. I'm pretty clueless all round arent I?
A penny for your thoughts.
Many many thanks for all help past and present.
Brad
Brad
