1967 500 Mercury 50 hp transom plate
pdreher
I was wondering how do I remove the transom plate on this motor. I see the 4 bolts but looks like there is some kind of shaft going through the middle. Any help would be great.
Chinewalker
Re: 1967 500 Mercury 50 hp transom plate
Are you referring to the swivel bracket? If so, then yes, there is a shaft going through there - the shift shaft. Only way to get that out is to pull the powerhead so you can pull the shaft out through the top...
pdreher
That is what I was wondering so if the power head is off what do I do then?
