Well me and cousin bought a project boat and we're having trouble getting the engine to fire up. There's no spark at the plugs, I read the cdi box on these goes bad all the time and I know it's pretty expensive.
I have power going in to the cdi box and I understand it's supposed to send power to the coil but I get nothing at the coil with a test light. Brings me to believe that the cdi box is bad.. now I saw something about converting to battery ignition using an automotive coil and a resistor but that only works if you have points and I don't think this motor does.(Model # V4TL-13a).
What do I need to convert to points?
I also saw people using an ignition box like MSD 6a with 2 coils, but I think they use the points as a trigger for the MSD. Is there another way I can trigger the MSD box without needing points? I know there's hookups for a magnetic pickup...any ideas on how to use some sort of hall effect sensor to trigger the ignition box?
