1966 mercruiser qutdrive
benn10
hey everyone i just bought a 1966 mercruiser 120 and it sat for 4 years when i got it engine would try to turn but would not took off outdrive and the engine turned over however the upper half was siezed up took the outdrive apart and lower half was in good shape could not turn shaft in upper can i with limited knowledge take it apart to get i9t unsized.
HT32BSX115
Re: 1966 mercruiser qutdrive
You can probably take it apart but you probably will not be able to put it back together.
The drive must be completely rebuilt.
You might be better off getting a new SEI drive to replace it with.
http://www.sterndrive.cc/
Cheers,
Rick
Ayuh,... I think a 1966 is too Old for the swap,....
Gettin' a 66 Fixed, or rebuilt might be tough too,... lotsa part #s for 'em are NLA...
benn10
what kind of outdrive can be used to replace it
zbnutcase
Nothing without updating to a much newer complete drive package.
do you mean new engine and outdrive.
Ayuh,... The 120hp motor can be Updated,...
The transom assembley,+ the drive are what's probably Obsolete...
You still haven't narrowed down Exactly what you've got...
Got a serial #, or Pictures,..??
benn10
serial number 1942453, so how or what do i need to update the motor?
PNW Driver
I have a 69 merc and I have been able to find everything I needed without too much effort. My local marine store carries most but I had to look a bit more for a few things. I'm not sure if we have the same drive or not. Just my two cents.
benn10
1966 17' maritime merc tri hull aluminum 120 4 cyl. has it cost quite a bit?I have found some avali.parts on line i really am trying to find a resonable fix for this problem i know i can get the seals fairly cheap and all the gears i could see looked good outside of a little rust. but we know rust is the enemy.Thanks for the great news on poss.being able to get parts.
benn10
well i managed to get the outdrive unseized.was not that tough ha ha.i also got the engine to run for a few sec. i think i hav eto replace the fuel pump anyone know if that will be a hard part to find org. or aftermarket.
fishrdan
Can't see the fuel pump in the pic, but I'm guesin :)rolleyes:) it's the old style Carter with the upside down fuel filter (filter on top), about $100 aftermarket, easy find. The fuel line between the pump and carb should be steel, not rubber hose, so you should get a piece of brake line and make yourself a replacement. Or, order a replacement if they are available, I just bent one up. With all the ethanol problems and an old fuel system (rusty tank?) you should add a water separating fuel filter, $30-50, could save yourself a lot of headaches.
On the seized/unseized outdrive, I would be suspicious of rusty bearings & gears and their condition. Have you popped the top cap of the upper unit to inspect the gears & bearings? I wouldn't venture to far from land with a questionable outdrive, could leave you stranded. Take it easy in the beginning and check the gear lube for rust/metal/water contamination often. Drain/refill if needed. Pressure testing the drive will show you if it needs to be resealed, and with water intrusion (rust) it's quite possible. Could be a ticking time bomb...
Have you replaced the lower unit water pump yet? Checked bellows? With a 66 I would expect a lot of maintenance items need to be addressed.
benn10
yes i have popped the top off gears look shiny almost new had very little rust sprayed in some pb blaster let sit overnight broke free with ease the large bellow needs replaced $175.00 for part got to pay to play yes it is thee old style fuel pump and i will definitly change to a metal gas line outside of that the motor sounds great for being 44 years old.
