1966 merc 500 carb removal
Andy in NY
Now that she is all tucked in bed for the winter, I am going to have the carbs rebuilt. Are they hard to remove? I do not have a manual for this motor yet, and won't be able to get one before I need to remove them. Can you guys help me? Thanks...
Laddies
Banned
Re: 1966 merc 500 carb removal
As you know you really need a manual, that said to remove the carbs on your engine you will have to start by rermoving the starter and magneto to get to the carb mounting nuts then remove the bolts that retain the filter covers and fuel lines
Andy in NY
Is there somewhere online that I can find step by step instructions?
How long should I expect it to take?
Laddies
Banned
NO, I have no idea of your mechanical skill
*EdC*
It's pretty easy..........
1. remove the cowl
2. remove the front and top support brackets
3. remove starter
4. remove coil
Should be able to get to the carbs then. You can get an exploded view at www.dougrussell.com
Ed
Andy in NY
Okay, starter off no probel. It's getting to the nuts on the other side that is proving difficult... any suggestions?
Andy in NY
Anybody?
I think I can get to the nuts by removing the magnito, but I cant figure out how to get the magnito out!
*EdC*
Hi Andy,
Although I'm not versed in your particular motor, I can tell you... You got to be very imaginative with your tools. I am almost done completely rebuilding my '69 Merc 800 and I've never rebuilt an outboard before. One set of tools I found to be helpful are Crows-foot sockets. They are kind of like an open end wrench, but fit on a ratchet. I Also found a factory manual is a must have. Consider getting their accompanying parts catalog too. Seloc manuals are OK. I used both, The Merc manual is geared toward the professional, and Seloc is more like a Chilton's. In my last post I gave you a link for exploded views.... Here's a better one, http://www.crowleymarine.com/
You can zoom in on the illustration to see excatly how things come apart.
Regards,
Ed
See you on the MFG board;)
Andy in NY
Hi Andy,
Regards,
Ed
thanks Ed.
Well, I finally got the magneto off. After I fought with it for 2 hours, I read on another forum that the shift linkage rod gets in the way, and shifting it into forward gear would help... sure enough, dropped right out.
The carbs were pretty straight forward to remove, but i did notice that you cant take the nuts all the way off until you break the carbs free from the block due to lack of clearence.
