racerdonnie13
Thread starter- Joined
- Sep 15, 2008
- 24
Ill try to make this as understandable as possible so bear with me. So on the control box i have 2 levers, the big gear selector/accecerator lever and a smaller black lever that seems to do with the accelerator also. When i start the motor up the black lever is all the way forward. When i shift into forward it automaticly starts to push the black lever backwards as i give it gas, but it will not go all the way back. I cannot get full throttle out of it untill i push the black lever all the way backward. When i go to slow down, i pull the shifter backward toward neutral the motor will go below idle and shut off. I have to slow down to where i think the motor is at about idle speed (still in forward gear), then bring the black lever back to the forward position. Then i can put the shifter back into neutral without the motor cutting off. It just seems like this is a little complicated to have to do all this. Any ideas?
